1 - 11 of 11 Posts
Anyone remove their steering wheel and remember the type and size of nut/bolt holding it on? Bentley just doesn't say and other posts say it is big....is it a torx or hex and I would need to know the size as if I get the airbag out and don't have the right size of wrench I'll be screwed.
TIA
Lefties have rights, too!
Dave,
You should of told me you wanted to do this as I could have loaned you my tools over the weekend.;)
Tom
I'm Urlik's Hero
I've had a cruise kit for ages, still haven't got round to fitting it and the only part I'm shying away from is removing the wheel.
Take detailed pics, I dare you!
Discussion Starter · #7 ·
Yeah I will if I am brave enough!
Dave,
Tom
Yeah I know! About two weeks ago I had the crazy relay clicking noise. It lasted a day and then went away. It happened again this morning. From what I have researched here I need to clean the contacts at the base of the turn signal indicator. Anyone have any idea how long this stupid task should take?
You can use a large Hex wrench, I will check the size when I get home.
If you are trying to get to the electrical connections at the rear you can remove the up colnum panel.
Discussion Starter · #9 ·
If you are trying to get to the electrical connections at the rear you can remove the up column panel.
Thanks....can I clean the signal contacts without removing the wheel?
1 - 11 of 11 Posts
