Startup idling problem
883 Views 8 Replies 5 Participants Last post by  DirtySanchez
I have this bad shaking when I start the car up. The revs go up as high as 1100 rpm and after about 5 seconds the car will sputter like the engine is going to die but then it goes back to normal idle. (800 rpms.)
Anyone have any ideas whats causing this? I already replaced my spark plugs and just sprayed the throttle body with a cleaner. Can it be my MAF? Secondary air pump?
1 - 9 of 9 Posts
Normally this will happen when the A/C is on. Today it was hot in toronto, were you using the A/C at all?
No Aircon. This happens almost always when I start up the car when the engine has gotten cold. Can this be coilpacks?
What year is your car...? How many miles?
Try cleaning your T Body. Usually works like a charm...
what motor do you have? year? millage?
2002 1.8T Passat 60,000 kms...
I already cleaned the throttle body but didnt take it out just sprayed the inside.
Had the same problem...
Natskiboy--
I had the same problem on my 2002 1.8t. We took it to the dealer and there was a technical service bulletin on the 2002 ECU software. They upgraded the software under warranty and it has been great ever since.
Good luck to you..
King Gordon
Re: Had the same problem...
King Gordon said:
Natskiboy--
Good luck to you..
King Gordon
Dont think thats feasible. My car is chipped.
O its under waranty isnt it? Im lost on this one...
1 - 9 of 9 Posts
