proud owner of a B6 passat with the 2.0T FSI BPY motor. current setup:
HPS air Intake
3 inch down pipe with cat res delete 2 O2 sensor, and using a O2 rear spacer to keep the CEL off
RSK coil over kit
Looking for a Tune. definitely want to go with a Stage 2, however not sure if I need a stage 1 prior to going to stage 2.
I have found several tunes with handheld install,
Unitronic https://www.moddedeuros.com/products...ed[]=10910
IE stage 2 https://www.moddedeuros.com/products...ed[]=13466
IE stage 2 gains on 91 octane are 60hp/90 torque
Unitronic are 60hp/ 88 torque however on 93 octane. highest we have here in Seattle is 91 octane.
what would you do?
HPS air Intake
RSK coil over kit
what would you do?
