As i said, car has about 95,000 miles on it, check engine lights comes on, comes up as mifire in cylinder #4. i remove the spark plugs and find them soaked in oil..is this normal? what could the problem be? :???:
I have never seen that in my life, that is NOT normal. You should go to a mechanic, you could have a serious problem with your engine.
Soaked on the outside or on the tip inside the cyl.?
If its on the outside, your valve cover gasket could be leaking into the plug well and could potentially cause issues.
If its inside your cyl... then you have a ring or guide issue.
