Sold! Thank you.
Brand new UUC short shift kit for Passat/A4 non-pushdown 5-speeds. Compatible with 99-01 B5 passats. Not sure about compatibility with B5.5.
$120 + shipping.
Derek,
Part number is A42-USS.
http://www.uucmotorwerks.com
Shift throws are reduced 20% for A4/Passat shift kits. Because the throws are shortened, the factory in-gear shifter "wobble" diminished while the overall shifting quality is improved.
Whereas most short shift kits would increase the effort in a negative manner, the following chart shows a shifting effort comparison before and after the installation of our kit:
Shifting Effort Comparison
Force required for 3rd to Neutral Shift:
Stock 3.5 lbs.
UUC Motorwerks Ultimate Short Shifter 4.5 lbs.
Force required for Neutral to 4th Shift:
Stock: 4 lbs.
UUC Motorwerks Ultimate Short Shifter 5 lbs.
