the deal finder!
i'm possibly looking into buying some hp evo 18x8 5x112, and was wondering if anyone knows the following:
-offset
-weight
-hub size (i.e. do i need a hubcentric ring, and if so, what size)
-bolt hole (will the 14mm size for vw's work?)
edit - can you use stock ball seat lugs with it, or do you need conical lugs?
the deal finder!
ok, so i asked hp and they told me that their side of the wheel is 73mm, so i guess i need a 73 to 57.1 ring.
does anyone know about the bolts?
Some HPs are 12mm bolt holes (for some mercedes). Ours is 14mm, so u better make sure they're the right size. Also, those rims come in 35mm offset. That's correct for our car, so look for that. I can't remember if I needed hubcentric rings or not. They dent pretty easily, so be careful.
$onny
