1 - 13 of 13 Posts
the deal finder!
pancreas said:
Smog pump? Or your lawnmower?
no lawnmower this came from my B5 :nervous:
actually, the lower tone noise was from the Chas bar which was sitting against the tranny pan, but that has already been removed.
Check to see if it is a checkvalve in the plumbing near the intake. The hoses will be about 5/16-1/2 " big. It will be a part the diameter of a half dollar and about 3/4" long. If it is, thats normal. My W8 has one that Rattles/clicks. A little annoying, but normal.
the deal finder!
i'll check it out...i don't mind the noise, just want to make sure nothing is broken.
Nah... check on top of the airbox, there is a little box type thing on top that clicks while the car is running, that may be what you are hearing :p
There's something called an EVAP on top of the filter box that clicks once in a while - that's what pumps gaseous fumes from the gas tank to engine to be combusted.
I know excatly what you mean. I have the same sound coming from that area. did you remove the cover (whatever its called) I started to hearing the clicking when I removed that cover.
B5 2K 1.8T
the deal finder!
Discussion Starter #10
B5 2K 1.8T
the cover over the air filter housing? yes i did, but i did put it back on. did you do anything to fix the noise?
Well the car was at a mechanic (changed my T. Belt, tensioner, coil packs) He did not put back the cover. I can't remember if I had that noise before I took it to him. but It seems to be a normal thing, as the guys here have indicated.
well it sound as if a tensionner has some dry bearings and maybe one of your belts is gone :eek:h:
the deal finder!
Discussion Starter #13
i doubt that the belt is gone at 35k. oh well, maybe i'll take it to the dealer and have them check it out.
1 - 13 of 13 Posts
