Sounds like you have a vac leak and if you have a vac leak, boost can be light. With car at operating temp, A/C off, vac should read 18-20 at idle in neutral, 20-22 when coasting in gear. These are approximates, but 10 psi is clearly low. Check all vac hoses for leaks.
