2 gauge battery wire is 1 foot short.
What do I do?
(a) crimp some 2 gauge to some 2 gauge with a cylinder of some sort.
(b) crimp ring terminals on both sides, and bolt 'em together.
(c) get a distro block and use it as a coupler.
(d) use a fuse holder as a coupler. <= probably won't work because my starter pulls what, 600 amps when cranking? Although I've read some battery relocation kits that have a 60 amp fuse... :crazy: Fuse is probably good so my car doesn't burn down in flames. Then again, there are kits without fuses...
(e) solder that baby to death.
(f) don't be cheap and buy new wire.
This is actually for a battery relocation, but I figure you guys play around with thick wires more than the normal human being does.
TIA.
TIA.
