1 - 11 of 11 Posts
the deal finder!
no, the trunk won't close. but with the trunk open, if you manually trigger the latch, and hit the remote, then it will unlock
Dan - call me...
So what was it?
Trunk microswitch?
well whaddaya know a low tech repair on a Passat. I didn't know that was possible :rolleyes:
they replaced the latch. the part was ~35.
Aha! :thumbup:
Thanks, my trunk latch seems to be working sporadically... no codes
with the VAG-COM either, so this may be it. :(
the deal finder!
Discussion Starter · #11 ·
Aha! :thumbup:
Green_Hornet actually found a possible solution, depending on the reason for the failure, if you don't mind tinkering.
1 - 11 of 11 Posts
