The power is adequate for what it is IMHO. Its enough to throttle steer it if you lose grip and need an emergency manuever (though the auto tranny kinda prohibits that), but don't expect it to send the tires smokin' at every stoplight. In fact, it has about the same power to weight ratio as a stock 150 hp Passat, which is adequate IMHO. You won't realize how great the low curb weight is until you find yourself taking corners flat out when you used to brake hard for the same corner in your Passat. :wink:
