I noticed there are few drops of coolant on the garage floor. The position is corresponding to the coolant drain plug. Does the drain plug have an o-ring? I tightened the drain plug but no luck. Anyone has experienced the same issue and what would be the fix?
Thanks.
I expect that there is an O-ring. But to get at it, you are going to drain a lot of coolant unless you seal off the discharge with a plugged piece of hose, and also plug the drain valve opening with something while you figure what to do with the seal.
The radiator drain can get fouled with any small particles in the coolant. You can try opening the valve for a few seconds to try to flush the particles out. I've had that happen and was able to flush it out by opening the valve for enough flow to clear it.
