Okay, I have had the car for almost two weeks. 1.8T 2003 B5.5. No CEL on, Car starts right up with the key turned, smooth idle and looking at the RPM gauge it's very steady at idle. Seems in the mornings when the car is cool it accelerated smooth and good power, but after the engine warms up or been driving for a while I have to push the pedal down at least half way to get good acceleration, it I push it further it takes off really fast. I live in Phoenix and as you know it's hot as hell here, 106 today. The car has 101K, Timing belt and water pump just replaced as well as cam and crank shaft seals, and two new axles. No oil leaks as far as I can tell. Temp stays right in the middle. The mechanic that did my brakes last week took it out right after and when he came back says I need new plugs as he was feeling the power loss. I realize it can be many things, I hope it's no issue with the Turbo... He will be replacing the plugs with the OEM NGK's next weekend as well as a new PCV and air filter. Do you think it may be another issue?. The car has been well maintained as the exterior and interior of the car is immaculate as well as the engine bay, very clean. This is my first VW so I am learning that Maintenance is critical on these cars, I knew that it would be somewhat costly to maintain but did a little homework before buying and also had a mechanic take a look before I bought it. After I figure out the power issue I am going to have all the fluids flushed as I don't know what the previous owner has done. Thanks for any input and advise.
