I have a 2003 4Mo wagon with 30V 2.8L AT, about 205k miles. For over a year it has had a slight shudder in 1st gear at the beginning of acceleration under medium or greater throttle. It only does if from idle to maybe 2-3000 rpm. Light throttle, no shudder.
Now I notice it a little in 2nd gear as well. So, on take-off most of the time I get light shudder/vibration in 1st, goes away as rpm increases, then into 2nd and light shudder again, goes away as rpm increases, and then all higher gears normal.
I just changed tranny fluid & filter again (was done at 100k also), and no change in characteristic. The sound is not metallic, and doesn't feel like any slippage. I'm not terribly worried as it has been going on a long time, but it sure would be nice to know what it is & fix if possible (practical).
I changed the motor & tranny mounts about a year ago, and no change there also. Have not replaced the front snubber yet, waiting to add this to the next front clip removal job.
