1 - 10 of 10 Posts
should i risk it? before i knew i needed special tool to remove cyl head bolts i used an alan wrench. now 4 of them they are stripped what can i do to get them out? :( can i get a metal bit and drill the heads of the bolts off and try and lift the head up off over them or am i S.O.L. :crazy: please any ideas at all? :cry: :cry:
Why on earth would you have one that?? :crazy: :crazy:
I'm pretty sure that's not enough clearance to use a bolt out extracter, so you'll definatley running out of choices.
If you drill them out you should have plenty of meat on the bolts to pull them out after the head is off. There's gonna be metal everywhere though.
Id be very careful......I shouldn't have said that, Its not like your going to be careless right!? I'm an ass. But, I would keep a tap and die on hand just incase I jacked something up.
pretty sure i didnt
pretty sure i didnt...i had the shop vac there while i was drilling PITA but i think i didnt get any thing in there but it was drill or new engine. what would you do?
6th Grade
Re: pretty sure i didnt
Hammer a 6 point socket over the head of the bolt.
1 - 10 of 10 Posts
