1 - 13 of 13 Posts
Should I connect the power antennae lead?
I searched for this but did not see a previous post. I have a 1999 passat wagon. I am installing an alpine 9815. I have a harness adapter that has wires for everything for quick connection, loving it. It has a wire for the power antennae lead from the deck, and there definitely is a wire coming into that spot on the factory harness. My only reason for hesitation is that I am using the powered antennae adapter for VW which has a red lead on it which I connected to the remote (turn-on) wire output from the alpine. Is it safe to connect the alpine's power antennae output to the factory harness also (as the harness adapter is obviously asking for)? I am working on it now so if I don't get a response soon enough I'll just go ahead with it. Thanks in advance for your advice.
Good thing you found it. You NEVER want to hook anything up to the K-Line in the car. There's a write-up here as well, but I agree, it should be a sticky or in the how-to forum. Make sure you use the correct leads for the antenna adapter and any amps you have or may add. If you wire them backwards then the amps will turn off when the cd player is on and only come on when the radio is on.
Paul :thumbup:
Attached Link
Maxx,
What is this link saying?
I installed an aftermarket deck in my passat and the k-wire I believe is part of the harness. Do I have to take the wire out of the harness?? Confused...
thanks
Re: Attached Link
carmine said:
Maxx,
thanks
If you used a Metra harness to plug into the stock wiring then you're all good.
Paul :thumbup:
Paul - this could be confusing - Beware using an old metra harness - they still have the lead installed.
You had mentioned a specific model #. But, many, me included - have old harnesses that get reused. I think mine is wrong now. I just slapped in in there. But, I'm going to check when I get a spare minute.
Paul When I picked up my Alpine 9835 the only harness the shop had(and included free) was an older one and had a blue wire looped back into the the Harness. So I removed both wires and tossed them in the garbage. It was not a metra Harness an said VW 87-up it might have been scocshe(sp). But hey it was free.
I have a question regarding the Antenna adapter. What is the correct way to hook up the red power lead? I have it soldered into my switched power that also goes to the deck, is this correct, or should I switch it to my remote turn on coming off of the deck? I won't use the the Antenna line coming off of the deck because I don't know if it is energized the entire time the tuner is in use or not.
Pete
thanks pual I will fix that when I install the the Ai-net cable and the xm tuner.
Pete
Paul - Does that switched antenna lead require low or high voltage - if you use only the low voltage antenna turn on from the deck will you need a relay?
Thanks
1 - 13 of 13 Posts
