Does anyobody have any links to instructions on how to install aftermarket springs and shocks? Also, is there anything else I should change out or add while I'm in there? Thanks for your help
It depends on how old the car is. You should check the control arms and tie rod ends
before you do the install. It is best to replace all that is needed at one time.
