1 - 13 of 13 Posts
So every time I start the car up(04 1.8t fwd wagon) my secondary air pump is louddddd. Assumption is that means is gonna go out soon but maybe yall have ran them for years just loud like that, I dont really know. Heading to LKQ tomorrow to grab some stuff but wondering thoughts on grabbing on from a car out there? Is this a common item to die? Is it worth rolling around on the ground out there for? Should I just grab a new one?
Side note...I had been under the car and never put the sheild back on like a dope. I dono what I hit but heard it bounce up in the car and tore my radiator in half. Ooops. Lesson learned.
You might want to assume that the inlet or outlet hoses are broken or torn. It gets super loud when they break. I replaced my pump to combi hose and it's so quiet, you can barely hear it over the elevated idle on cold starts.
I can just barely hear my SAIP when I'm in the car, even with the windows open. If you're is making a racket then somethings wrong.
I'm sure the pumps wear out eventually but broken hoses or stuck combi valves make them die a much quicker death since moisture or condensation from the exhaust gases can flow back into the pump and ruin it that way. Most of the parts probably aren't expensive but I'm sure the junkyard parts would be cheaper. I'd use junkyard parts if they look OEM and in good shape otherwise just get new stuff. Also, it never hurts to practice a bit on a junkyard car if you have time. R/r of the SAIP is not a big job but it never hurts to try it the first time on a donor car.
do not know your location but in near future in my case N.E Ohio, you will not hear the pump as it does not operate (ECM command) under I believe 39 F. degrees Late October thru, March. And that leads/contributes to failure, leaking fumes from combi, moisture,condensation, etc. Without going to service position you can get to pump itself..... ah ,ah relatively (used loosely) by removing fender liner
Mine was torn up going on some rough dirt roads in Utah last fall. The front half is there and held in with Zip ties. I have a metal one sitting in the garage to install when I swap the 2.0 stroker motor in next year.
So, you decided to keep it?
:) I've always wanted to keep it, but I am torn over the waste of it sitting. Since my wife wants to keep the Golf as a backup for the kid's cars, I would be left without a car. So yes, I decided to keep it and install everything I have. It will be a long process as my back pain only allows hard work every 2-3 days, including the yard work and work on our other cars.
Morning. My pump was so loud my daughter said it was embarrassing when I dropped her off at school. Hey, if your a little bit mechanical - do what I did, pull it out, and put some new bearings in it. Provided that is that the rest of it is ok. I think, and the cost was so small, that it cost me a few hours to rebuild and $25.
Please post either a writeup or at least a parts list that you used. I am sure several people could use that info.
Loud when dropping off at school?
The SAIP only runs 60 or 100 seconds (depending on engine), then for a few seconds later for self test.
I was thinking the same thing as well. Unless school is right across the street.....
1 - 13 of 13 Posts
