And one question, can it be connected somehow to increased fuel consumption?
Thanks Frescox2 on what Scott said. Additionally:
You can search the forum for "P0411" (the fault code) and "SAIP" to read more about this issue--you'll get lots of hits.
Two other common causes of this code, both of which I've experienced:
- The relay that switches power to the SAIP, relay 373, is sort of undersized. If yours is original, it probably needs replaced. It's located in the ECM box.
- Several of the vacuum hoses in your engine tend to get very hard with age. One of those operates the combi valve, and if the combi valve doesn't operate you'll get P0411. See my DIY in the info base: http://www.passatworld.com/forums/61-b5-information-base/337838-diy-how-replace-1-8t-awm-vacuum-hoses.html
You don't say if your Passat is an 01 (B5) or 01.5 (B5.5, "New Passat") like mine, but the engines are basically the same vis-a-vis vacuum hoses.
If the SAIP is not working, it will not damage anything, it only runs for about 90 seconds at a cold start of the car. It is there to aid in heating up the cat faster from cold.What if I don't fix the problem, what can it damage, as it is for emissions? I cannot replace motor until I make some money with my car.
