Runs fine but P1136 keeps popping up
754 views 1 reply 2 participants last post by  PZ
I have a 2000 1.8l with a manual transmission. It seems to run fine but P1136 keeps coming up. I will clear the code but after about 20 minutes its comes back on.
It also has a whining sound when you first start it up cold. It lasts for about 30 seconds or so, then goes away.
#2 ·
Start with checking all of the vacuum lines and hoses. One is probably leaking. The whining sound is the SAIP. Eventually it sounds like a jet engine and after that it will fail. You would need to check the combi valve for proper operation and replace the pump when it fails.
