i heard that this stuff increases power, and works wonders on your engine. does anyone use this oil, or know anything about it??????
tia
-chris
tia
-chris
I've got a quart of Royal Purple 5W30 in front of me, and it says right on the bottle:SilverFlash said:These "boutique" oils are questionable at best :nervous:
Why even use them when there are many other PROVEN oils on the market.
Go for an API, ACEA certified oil--not just one that says it SHOULD meet the requirements of abc spec :shock:
How old was the oil in the Z28 pre-dyno? What type of oil? etc etc etc . . . you see how easily falsified this test could be?JETninja said:Saw a MuscleCar show on Speed yesterday, they ran a Z28 before/after on the chassis dyno. They changed Engine, Trans, Diff, to Royal Purple.
Before - 302HP
After - 308HP
(IIRC! At least it was something like that...)
I also remember HotRod Mag in about '83. A Thunderbird Turbo Coupe (2.3L SOHC Turbo), Mobil 1, same sorta test. +8 HP.
Of course most all oils have more friction reduction additives since '83. But a good Syth is more oil per Qt. Less additives are needed....that and the designed molecular structure can do a lot for friction, at the same time lowering temps. All well proven by many tests over the years.
I wonder if the B5 community can come up with a test-supported recommended oil brand/weight list -- and post it in the info forum. IIRC, those oil-test kits are only $20 for a lab analysis. It would be cool if we could get several dozen members to have their oil tested and then post a chart of the results (with comments by AA, if we can talk her into it).atomicalex said:Ask any of the boutique oil vendors for their engine sequence data. They don't have any.
While the base formulations of these oils are very good, they are rarely tested under the engine sequences as that testing is very expensive (buy a motor, run the crap out of it, tear it down for measuring, toss it) and apparently our friends at these shops don't care to spend the money. If I get one more 4ball result from these guys, I think I will self-combust. They don't even run HFRR, the current state of the art in engine oil bench testing.
I'll stick to guys with oil research programs that are on par with my lab.
