1 - 8 of 8 Posts
Okay, I am a straggler in the rotor group buy - just had my 40k service done and need brakes/rotors...but WHICH ROTORS?!
I am ashamed to admit that I don't have the tools necessary to remove the wheel and simply look for a P/N or measure... I'm hoping that a more-knowledgeable Dubber can help:
2001 old-style B5 GLX 4Motion Variant
relevant VIN 3B2 1E0
Front rotors - 288mm or 312mm? (I *think* 288)
Rears - standard 245mm or some kind of 4mo-only special rear rotors?
I want to do the S_Klass group buy, but want to be sure I get the right parts -- any help would be greatly appreciated -- THANKS!
288x25 is the standard size.
You can upgrade to the 312mm size if you buy the pad carriers from an Audi TT. (roughly $140ea).
ecs and purems offer kits with rotors and carriers for the upgrade.
You probably have the 288 fronts and the 245 rears like most Passats. To check without any fancy tools, take two straightedges like two rulers and hold them flat across opposite edges of the rotor through the wheels. then have a friend measure between the straightedges on the outside of the wheel while you are holding them. You'll know the difference between 11.1, 11.3, and 12.3 pretty quick.
Good luck,
Carl III
Discussion Starter · #6 ·
Great suggestion! This explains why I am not an engineer -- thanks!
00Psst - does the Bentley make any mention of different rear discs for the '01 4Mo Wagon? Thanks for the help, I appreciate it!
I actually just checked the Bentley for you again because I hadn't noticed that you had the 4 Mo the first time I replied. I am assuming you have the V6 since you've got the 4Mo. Here's what it says for you:
2001MY, 2.8L, 4Mo
Front brake disc = 312mm x 25mm
Rear brake disc = 256mm x 22mm
Sorry about the confusion before.
Discussion Starter · #8 ·
No group buy then for me most likely :sad:
Luckily, ECS pricing is still quite reasonable.
Thanks for the help! Now to confirm with some nifty measurement techniques...
Varies Widely
Okay - I manufactured a caliper measuring tool:
288mm fronts
245mm rears
1 - 8 of 8 Posts
