1 - 20 of 50 Posts
Rotor/pads install for dummies. Step by step info inside.
Im not sure if anyone done this yet, figured it would be nice since this Q gets asked alot. And we can also save our fellow B5ers $750 off dealer price.
PLEASE READ: Do at your own risk.
I make no guarantee regarding the above procedures and am not
responsible for any brake problems, accidents, etc.
Also please don't do this with jack holding your car up invest 10 bucks and do it safely!
This brake job was done on 1999 B5
ROTOR/PADS INSTALL
Front:
Tools needed:
-7mm allen key
-17mm ranch/rachet
-C clamp or large pliers
-jack stand (Autozone $10)
Parts needed:
-2 new rotors
-front brakepads
-brake quite
-neversieze
Step 1
Take off the wheel.
Also open the brake resavoir. Sometimes when you retrack the caliper it might overflow.
So put a rag around it also.
Step 2
Take the tension spring off
Step 3
Remove 2 black caps in the back off the caliper
Step 4
Remove 2 bolts, use 7mm allen
Step 5
Press against the rotor and caliper to loosen it
Step 6
Slide off the caliper
Step 7
Remove old brakepads
Step 8
Remove 2 bolts and bracket, use 17mm rachet
Step 9
Remove rotor, it should slide right off, if not use a hammer to tap on it here and there.
Step 10
Apply neversieze
Step 11
Apply new rotor
Step 12
Reattach the bracket
Step 13
Retract the piston using big pliers or C-clamp
Step 14
Apply brakequiet on the back of new brakepads
Step 15
Apply brakepads, as shown in the picture
Step 16
Slide on the caliper
Step 17
Reapply the hex bolts, you might want to torque these to 92ft/lbs. I didn't
Step 18
Replace the plastic caps
Step 19
Replace the tension spring
Done
Rear:
Tools needed:
-13mm ranch
-15mm ranch
-caliper retract tool http://www.autotoolexpress.com/reardisbrakc.html - VW tool is cheaper
you can also use needle pliers but it takes longer and its more PITA.
Parts:
-Rear rotors
-new brakepads
Note: You are going to need put something under front tires cause you cant have the E-brake on.
Step 1
Take the wheel off.
Step 2
Unscrew the caliper bolts using 13mm ranch and 15mm to hold it in place
Step 3
Pull off the caliper
Step 4
Slide off the rotor, you do not need to remove the bracket, slide on new rotor.
Step 5
Retract the piston using either the tool or needle pliers. Screw and push clockwise.
Step 6
Apply brakequite to the back off the brakepads! See pic above in front brakes section.
Step 7
Apply brake pads
Step 8
Slide on the caliper and screw in the bolts.
DONE
PLEASE READ!!! Make sure you pump your brakes few times before driving!!!They should go down all the way the first time you step on them. Just pump them up.
Good Luck
Please inform me if you notice any mistakes!!
<![CDATA[Im not sure if anyone done this yet, figured it would be nice since this Q gets asked alot. And we can also save our fellow B5ers $750 off dealer price.
ROTOR/PADS INSTALL
Front:
Tools needed:
-7mm allen key
-17mm ranch/rachet
Parts needed:
-2 new rotors
-front brakepads
-brake quite
-neversieze
Step 1
Take off the wheel.
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Apply neversieze
Step 11
Apply new rotor
Step 12
Step 13
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Re: Rotor/pads install for dummies. Step by step info inside. (passaturbonium)
Excellent write up, passaturbonium! Just what a poor by like me needs. Thanks
Re: Rotor/pads install for dummies. Step by step info inside. (CG)
Very nice writeup. Believe me, boys and girls, it's pretty easy to DIY, and save a lot for other mods.
Re: Rotor/pads install for dummies. Step by step info inside. (slimmn)
I have a quick question...in the past when I've done brake work, I have typically replaced the springs, etc. Does the manual recommend the change, do new springs come with the pads, or if not, does anyone know if a hardware kit is available (part #, too, if you know)?
Re: Rotor/pads install for dummies. Step by step info inside. (Altair 4)
Excellent write up
I'm suggesting this clubb5 website should open new corners, one is "maintenance tips" and another is "mod tips" to collect those informative write-up like what you did.
what about bleeding the brakes or do you not need to do this?
oh boy... here I go...
I was taking my car in to do all four brakes TODAY! (Zimms and Mintex)
now I'm thinking about doing it myself... Thank you Turbonium for making my next weekend a very greasy one!
Q: are there any special setting for the C brake? and what about pedal feel, is that directly related to the rotor/pad combo?
thanks!
Discussion Starter · #11 ·
Re: Rotor/pads install for dummies. Step by step info inside. (renato)
Im not exactly sure what you are saying here......whats a C brake?
Forgot VERY IMPORTANT!!!
Edit: Make sure you pump your brakes few times before driving!!!
I wouldn't want you driving thru the back of your garage or into a tree.......
<![CDATA[Im not exactly sure what you are saying here......whats a C brake?
[Modified by passaturbonium, 10:59 AM 1/13/2003]
passaturbonium: you left you step 1.5 in the rear brake: relase the parking brake.
Otherwise, you'll never remove the pads.
As often as I've done this, I've never taken the time to do all of the pics like you've done. Good work.
I meant the hand brake, is there anything I have to do (besides releasing it
) after the job is done? setting the tension, pulling cables, etc...
I'm going for it...
nope. don't have to mess with the parking/hand brake after you're done. have fun.
oh and if anybody is using the non plated aftermarket rotors e.g. zimmermans, you might want to paint the hub with high temp paint to avoid that oh so glamorous rusted rotor look.
Nice writeup!
Re: Rotor/pads install for dummies. Step by step info inside. (DaddyMatt)
Just being picky, but on the rears the directions never say to reinstall the rotor!
Great writeup though
Awesome guide for us dummies.
This should be in the FAQ section.
Re: Rotor/pads install for dummies. Step by step info inside. (Gimps Unlimited)
Definitely a page to be archived.
1 - 20 of 50 Posts
