1 - 9 of 9 Posts
2018, Volkswagen, Passat R line
Hey guys, hope you all had a safe and restful weekend!
I am planning to switch out my 235/40 R 19 92H stock rims with Rotiform 18x8.5 et35 5x100
At the website of UroTuning I have the option to choose different sizes on a drop down Menu. See attached image.
I just goggled my Rim size and Bolt pattern;
19x8 ET48 5x112
Can anyone confirm these numbers? Would that be my actual rim and bold pattern that I need to get?
I understand that I’m downgrading from 19” to 18” rim. My question here is, do i need to get right at my +40mm offset here? I wouldn’t mind being a little over (not flush) if space and Performance allows it!?
Thanks so much in advance! Would love to hear any suggestions, and or opinions 😃😎
Much appreciated!
Communication Device Mobile device Gadget Portable communications device Font
· Moderator/Administrator
If you size your tires correctly to equal the same overall diameter, you can do the same offset. You can probably get away with 10mm.
Take a long ruler or something similar length and thin and lay it on the outside vertically across the center of the wheel/tire into the wheel well. That will show you how much room you have to work with.
Pics of how the stock wheels sit now?
Reactions: rline18
sorry about the late reply. Just been swamped with work so much. Thanks a bunch 🙏 I would have to do all that on the weekend. 10mm is not too bad. Definitely going to double check making sure it doesn’t look odd or interfere with anything in the wheel well etc.
i also came to think about the tire itself. Should I stick with the size and type of what’s installed right now or should I go low profile. Considering the streets here in LA, I probably won’t go less than what I have 😅
here are some images I took yesterday
Wheel Car Tire Land vehicle Vehicle
Wheel Tire Car Vehicle Automotive tire
Plant Wheel Tire Hood Automotive tire
FYI:
FYI:
FYI:
Dankeschön captainfantastic! Werde da ma heute Abend reinschauen 😀🙏
Discussion Starter · #7 ·
Update! first pair of wheels came in last Friday. Tomorrow the other two. Rotiform Blq 19x85 5x112 Silver Machines 45mm.
Not going to install them yet. I’m just going to wait until I get the car lowered.,Or should I put them on already to see where I’m going to be at when installing the coil overs?
hope everyone had a safe weekend!
Wood Rectangle Flooring Publication Font
Automotive tire Alloy wheel Rim Bicycle part Spoke
Discussion Starter · #8 ·
Update!!! soo... I decided to install the wheels before the lowering. Honestly, I couldn’t wait any longer 😁 I installed then without any spacers. Out the box and on the car. Here are some images.
Looks good!
1 - 9 of 9 Posts
