I'm feeling optimistic for polishing the crank. I'll do some light polishing based on some videos online and see if it will make it smooth with very little polishing, just hoping I wouldn't have to get a oversized bearing (I mean it can't get much worse right?? Polishing or used crank). I just don't think I can put anything more into it right now. I have put just under $3,000 into it within the last 6 months (timing belt failure, and now this). The way I am thinking about this here, is if it doesn't work, I can more easily take everything apart since none of the bolts will be seized anymore, and I have an idea of how everything is done, so theoretically I could have it back apart again in two weeks or so if need be(Bought everything on FCP, so I can get free replacement).
I planned on doing a full rebuild at 200k miles which is my goal to get to until then, but may just have to do that at 180k miles instead. I'll try to polishing the crank today and get an idea, I'm just really hoping it isn't too bad, but it was bad enough I could feel minor to a bit more than minor grooves on the crank.
Wish me luck.
Wish me luck.
