Hey guys!
Hoping for some recommendations on replacing the rod and main/crank bearings.
I was driving home from work the other day and my low oil pressure light came on, pulled over and checked oil level, looked fine. (250 miles after I finished my top end rebuild after timing belt snapped) I was 3 minutes from home so I limped it back and got it up on jacks and dropped the oil pan, oil pickup was completely clogged with plastic (likely from timing chain tensioner that failed 40k miles ago and was replaced at a shop) and a bunch of what looks to be bearing material, there was a mountain of debris right under the pickup. At idle on startup it sounded fine, but after it reved down I could hear what I would guess to be rod knock or at least I think it sounded like it. Ultimately don't wanna risk anything and just want to replace the bearings.. which leads me to my question. What is the best way to replace them? I'm working in my garage and I have 2-3ft of clearance max in front of the car. Would it be recommended to pull the engine and transmission out the front?, drop subframe to drop the upper pan?, or something else. I've never done the bottom end before, so I have no idea what to expect. Also have never taken an engine apart prior to October 2021. I have jack stands and a 3 ton floor jack. I can buy an engine hoist/puller if absolutely needed.
Anything I should look for in terms of the journals/bearings? I did manage to take one rod bearing out and it looked okay-ish, was mostly smooth with one minor groove, but yet again I have no idea what to expect. Please let me know if you'd like any more photos!
Also looking at Glyco bearings from FCP, any experience with that brand? 1 2 3
Thank you for whatever you guys can recommend!
Jack
Jack
