Salty Moderation Stylez
Type B5 said:
Is it possible to change the offset of a rim? Any rim shop or someone able to do it?
depending on the back pad fo the wheel some shops can shave a few mm's and still be safe. Most cases you won;t get more than 3mm though
Wont the spacers just push the wheel out more?
yes, the lower the offset the further out the wheels stick...
20mm offset looks further out then a 40mm offset..
thats why Clay said
You can use spacers to lower an offset. Don't know of anyway to make an offset greater. I wouldn't recommend it if there is.
:) hope that clears its up?
