1 - 2 of 2 Posts
Ok well at first I had a problem with my no. 14 fuse blowing and tracked it down to my overhead lights shorting out. Unplugged it and the fuse stopped blowing. But ever since Ive been having problems starting my car on occasions. When it happens my alarm works and my door locks work but I cant start the car and I cant control my windows. What could be the problem??? I have to turn the key on and off over and over till it starts up. Sometimes I can hold the key in the start position for a few seconds and then it will start as well. Today it started happening every time I tried to start the car after getting out and having it sit for 10 mins or more. Usually it would just do it at the beginning of the day and the rest would be problem free. It also starts up if i turn it off and then turn it back on, its just if it sits for longer than like 5 mins the problem comes back.
Discussion Starter · #2 ·
ok well ive been doing some research and decided to go take a look at my CCM...i pulled it out and the wires going from it are broken. The problem is they were broken or got broke when I pulled the CCM off and i dont know how they connect. I have 3 blue/white striped wires all disconnected that were going to the CCM. I also have two blue/black cables disconnected on that side of the CCM. Then I have two wires coming from the CCM one is blue/white and blue/black. So quick question, I was going to connect them anyway but does 3 wires connect to that 1 wire and the other 2 to the other 1??? I was going to hook them up anyway but if someone could answer i would appreciate it.
1 - 2 of 2 Posts
