Thanks for all the help guys. I finally got the VCDS and got a complete scan done today. Right now I'm chasing the Parking Brake Fault, an intermittent wheel speed sensor is next, as I have the rear of the car lifted. Then next on the list is the two airbag faults related to the rear seat belts.
I'll post the first scan. I'd like to know how to test the harness side of the EPB to make sure power is making its way to the motor, as well as bench testing the motor before buying a new caliper or motor.
Any other insight based on the scan or past experience is greatly appreciated!
Thanks!
Thursday,07,November,2019,11:33:19:02347
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWLK73C77E002377 License Plate:
Mileage: 246380km-153093mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
6D 72
VIN: WVWLK73C77E002377 Mileage: 246380km-153093miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 F HW: 3C0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H10--- Serial number: VWZCZ000000000
Coding: 040C010A19070160
Shop #: WSC 01057 444 54395
VCID: 2313E8D0F7D56AAFF45-8076
4 Faults Found:
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 244438 km
Time Indication: 0
Date: 2019.02.25
Time: 08:19:47
Freeze Frame:
RPM: 1774 /min
Load: 21.2 %
Speed: 50.0 km/h
Temperature: 70.0°C
Temperature: 2.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.478 V
001299 - Incorrect Immobilizer Key
P0513 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 245972 km
Time Indication: 0
Freeze Frame:
RPM: 1315 /min
Load: 32.1 %
Speed: 0.0 km/h
Temperature: -4.0°C
Temperature: -5.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.430 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 246358 km
Time Indication: 0
Date: 2019.04.06
Time: 10:23:51
Freeze Frame:
RPM: 1228 /min
Load: 48.2 %
Speed: 0.0 km/h
Temperature: 11.0°C
Temperature: 14.0°C
Absolute Pres.: 960.0 mbar
Voltage: 14.478 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 246358 km
Time Indication: 0
Date: 2019.04.06
Time: 10:24:06
Freeze Frame:
RPM: 1102 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 31.0°C
Voltage: 14.224 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 HJ HW: 09G 927 750 CJ
Component: AQ 250 6F 1068
Revision: 00H38000 Serial number:
Coding: 0000072
VCID: 0059875C460391B7C97-8054
2 Faults Found:
01682 - ABS Wheel Speed Signal; Rear Right
013 - Check DTC Memory
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 201
Mileage: 237231 km
Time Indication: 0
Date: 2018.09.17
Time: 21:59:28
18253 - Please check DTC Memory of Steering Electronics (J527)
P1845 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 193
Mileage: 246365 km
Time Indication: 0
Date: 2019.07.07
Time: 13:00:56
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0100000370
Coding: 0046523
Shop #: WSC 05311 000 00000
VCID: 323D1D94B82FF3270F3-8066
5 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 120
Reset counter: 161
Mileage: 244069 km
Time Indication: 0
Date: 2019.02.16
Time: 00:56:44
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 1
Reset counter: 161
Mileage: 244069 km
Time Indication: 0
Date: 2019.02.16
Time: 00:56:44
01542 - Yaw Rate Sensor (G202)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 201
Mileage: 246365 km
Time Indication: 0
Date: 2019.07.29
Time: 00:00:20
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 201
Mileage: 246365 km
Time Indication: 0
Date: 2019.07.29
Time: 00:00:21
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 201
Mileage: 246365 km
Time Indication: 0
Date: 2019.07.29
Time: 00:00:21
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 6889BFFC4E7349F7617-803C
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000002285046
Coding: 148C0F0340041A00400A00000F00000000285D435C0000
VCID: 372B2C80534D160F38D-8062
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
5 Faults Found:
00532 - Supply Voltage B+
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 164
Mileage: 246389 km
Time Indication: 0
Date: 2019.07.29
Time: 00:01:00
Freeze Frame:
OFF
Voltage: 15.70 V
OFF
ON
OFF
OFF
OFF
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 203
Mileage: 246365 km
Time Indication: 0
Date: 2019.07.27
Time: 19:05:00
Freeze Frame:
OFF
Voltage: 8.20 V
OFF
OFF
OFF
OFF
OFF
02389 - Release Signal Transmission; Position P/N
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 204
Mileage: 246365 km
Time Indication: 0
Date: 2019.07.07
Time: 12:55:00
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 204
Mileage: 246389 km
Time Indication: 0
Date: 2019.07.29
Time: 00:39:00
Freeze Frame:
OFF
Voltage: 15.40 V
OFF
OFF
OFF
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 203
Mileage: 246365 km
Time Indication: 0
Date: 2019.07.27
Time: 19:04:00
Freeze Frame:
OFF
Voltage: 6.95 V
OFF
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7E0015953
VCID: 2A0D05F490FFBBE7B73-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 164
Mileage: 246389 km
Time Indication: 0
Date: 2019.07.29
Time: 00:00:00
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0N AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3PR122UH
Coding: 0012366
VCID: 2E0509E4AC17D7C76BB-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000031W6R
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0D32713DDÿ†63
Subsystem 5 - Serial number: 2713DDÿ†6342MSME0D2D480FRÿ†63
Subsystem 6 - Serial number: D480FRÿ†6351HTS63IKQ9KA2Vÿ†63
Subsystem 7 - Serial number: Q9KA2Vÿ†6361HTS63IK6KA337ÿ†63
Subsystem 8 - Serial number: 6KA337ÿ†63727TS6I2II6N92Cÿ†63
Subsystem 9 - Serial number: I6N92Cÿ†63827TS6I2IIQL83Vÿ
Subsystem 10 - Serial number: IQL83Vÿ
2 Faults Found:
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
001 - Upper Limit Exceeded - MIL ON
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507R
Coding: 0002014
VCID: 313F1298BD29C83F769-8064
1 Fault Found:
02413 - Switch for Selector Lever Position P Lock (F319)
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Component: KOMBIINSTRUMENT VD1 4240
Revision: X0033000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 01057 444 57651
VCID: 333318904735FA2F045-8066
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 246365 km
Time Indication: 0
Date: 2019.07.27
Time: 19:04:32
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05C060C2B
Coding: 3FFD0E0CD32002
VCID: 211FE2D8EDC978BFE69-8074
No fault code found.
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 3C0 919 965 A HW: 3C0 919 965 A
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1339817TPYHF02
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: IMMO 041 0364
Revision: 00041000 Serial number: VWZCZ000000000
Shop #: WSC 01057 444 87930
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
2 Faults Found:
02861 - Electronic Steering Column Lock Check Sum Error
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 180
Mileage: 245972 km
Time Indication: 0
Date: 2019.03.23
Time: 07:11:51
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0001205
VCID: 363521845447EF0723B-8062
2 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
1 Fault Found:
000 - -
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ46 RDK 041 0213
Coding: 13900E88D1032E521804141FF00A0F0E081800
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
3 Faults Found:
00896 - Trunk Lock Unit (F256)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 204
Mileage: 244174 km
Time Indication: 0
Date: 2019.02.21
Time: 15:20:36
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 200
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 204
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
Shop #: WSC 131071 1023 2097151
2 Faults Found:
02432 - Supply Voltage for Left Parking Brake Motor (V282)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 162
Mileage: 246368 km
Time Indication: 0
Date: 2019.07.29
Time: 00:02:48
Freeze Frame:
Voltage: 12.21 V
Count: 86
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 254
Reset counter: 164
Mileage: 246384 km
Time Indication: 0
Date: 2019.07.29
Time: 00:47:17
Freeze Frame:
Voltage: 13.04 V
Count: 236
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 HW: 1K0 035 180
Component: Radio ZSW 015 0037
Revision: 00015000 Serial number: VWZ5Z7E6260238
Coding: 0040401
Shop #: WSC 39612 828 149130
VCID: 5DE79E2891311C5F821-8008
1 Fault Found:
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 202
Mileage: 246365 km
Time Indication: 0
Date: 2019.07.27
Time: 19:04:42
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703 A
Component: Tuer-SG 021 2505
Coding: 0000144
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0391
Coding: 0100101
1 Fault Found:
00667 - Ambient Temperature Signal
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 204
Mileage: 246389 km
Time Indication: 0
Date: 2019.07.29
Time: 00:47:17
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 B HW: 3C9 827 383 C
Component: J605 HECKDECKEL 0402
Revision: 00H19001
Shop #: WSC 23250 384 715754
VCID: 3039179CB623C137797-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0402
Subsystem 2 - Serial number: 0500H19001001A0090ÿ
3 Faults Found:
00317 - Rear Lid Control Module (J605)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 204
Mileage: 220133 km
Time Indication: 0
Date: 2017.02.01
Time: 09:09:02
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 204
Mileage: 246369 km
Time Indication: 0
Date: 2019.07.29
Time: 00:05:58
02786 - Module 2 for Hatch / Trunk Lid (J756)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 246389 km
Time Indication: 0
Date: 2019.07.29
Time: 00:42:38
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704 A
Coding: 0000144
End----------(Elapsed Time: 01:40, VBatt start/end: 13.1V/12.4V)-----------
