1 - 20 of 26 Posts
2x Passat B5.5 1.8T -03 -04
Hello!
Replacing my ac compressor tomorrow. According to the seller it's not pre filled, but they can't say how many ml I should put in it?
This is the compressor I bought
Discussion Starter · #2 ·
According to that pdf it could be pre filled, but they still want the installer to drain the oil and put the required amount in it.
Found this, but it doesn't say total amount
The Bentley has a breakdown of the new oil distribution, 50% compressor, 10% condensor, 10% suction pipe, 20% evaporator, 10% accumulator.
· PassatWorld Elder
The Bentley Manual says a specific amount of PAG oil to used in ounces (U.S.)
I think it's close to 6 ounces. But I would have to check that.
To get the proper amount of PAG oil the system should fully evacuated and then the PAG oil and R134a introduced into the system with specific amounts.
Reactions: Arn
I have only access to a vacuum pump, is that what you mean by evacuate?
Please check the total amount, would be very kind of you
· PassatWorld Elder
Straight from Bentley Manual.
So I was off a little bit.
Remember these are the U.S. specs.
You have to know what engine you have, what a/c compressor (note different PAG oils for different compressors - and yes it matters).
The compressor ships with proper amount PAG oil for the whole system. This would be for Genuine VW/Audi spec compressors.
Aftermarket compressors I don't know what the procedure is.
103576
103577
Reactions: Arn
Discussion Starter · #7 ·
Thanks! That's what I needed. I have the correct PAG oil at home.
That's a total of 250 ml in the system and 50% goes into the compressor.
On a new compressor, you get the oil out before installation by turning I it upside down, so the ports are facing down, then rotate the clutch by hand until all the oil comes out. Catch it in a pan, pour into a beaker to measure and top up as needed. Then you pour it back into the suction port while very slowly rotating the clutch.
Your Danish friends show you here after about 5:45:
Discussion Starter · #12 ·
I'm confused. Why only 175ml? The book says 250ml.
The total amount is 250 ml in the system id, but it's devided into this
For compressor 50% of 250 ml is 125 ml.
And I just realized I have filled too much oil in the compressor 175ml instead of 125, god damn. I haven't run it yet, so it's fixable.
Talk about black out.
· PassatWorld Elder
Your reading into this whole thing all wrong with the system capacity percentages.
This what the system capacity percentage chart means:
As the system is functioning the oil / Freon is flowing through all of the system components, at any given time the percentage of oil in the component is an approximation of said percentage.
The percentage chart is not to be used for gauging how much oil you need to introduce into the system for proper functioning. It is merely used for informational purposes only.
You should be using a full 250cc of PAG oil.
Discussion Starter · #16 ·
Are you 100% sure about this?
· PassatWorld Elder
My previous post was a bit misleading, so let me clarify something here.
You already have an existing system that has been under operational conditions.
In your case the separate component percentage chart does not come into play.
It only applies when the entire a/c system is replaced as a whole.
You need the full 250cc of PAG oil in the compressor. As soon as the system is cycled for the first time after re-assembly the PAG oil will get distributed throughout the whole system.
I'll put my reputation in this forum on the line about this.
Discussion Starter · #18 ·
You can be right and I can be wrong.
What I have previously been learned is when you are replacing individual components like the compressor, you still have a lot of oil in different parts of the system, not everything is dumped back to the compressor.
So if you fill your compressor to max (factory spec max) with oil without flushing all other oil out you will probably risk having to much oil in the system.
I don't think my vacuum pump will remove the oil that's left in other ac components. But it's a different story if you totally flush or totally replace every part of the AC system, that's my understanding.
So when replacing individual parts it's a guessing game how much oil you have left, but the Bentley manual gives you a rough idea of how much is left.
I should have said this earlier, but it's a -04 B5.5 1.8t.
And if I'm wrong, that's OK then I have learned something new.
· PassatWorld Elder
(grammar)
I just want to add something here. I'm not trying to imply that I'm right and your wrong in an arrogant way. I'm just saying what I know to be true after servicing quite a few a/c systems.
Back in the old days of R12 I used to do all of my own a/c service. But since R134a I've left it to the professionals. I just didn't want to reinvest with all new equipment.
I went through a number of shops before I found a guy that really knew his stuff.
What I've learned from him is the information that I go by as standard.
I will add, when I do any kind of a/c service that has compromised the Freon charge in any way shape or form, I always have it evacuated, vacuum leak tested and then recharged with specified fill quantities. My source for a/c service charges me $120 for the whole shebang. For the 90 minutes or so that it takes, that's really a fair deal in my eyes.
Anyways, in todays world the well equipped shop has an a/c machine that is fully automatic, takes any and all guess work out of the equation.
The only thing it doesn't do is hook itself up to the car.
Reactions: VAGguy and Arn
1 - 20 of 26 Posts
