Keep getting the code for the Bank 1 Cam Position Sensor even though I replaced it. I finally got time to investigate and found the new CPS mangled and the impulse rotor bent. Here is the image:
So I need to replace the sensor and impulse rotor. I have a couple of questions related to this job...
1. Is it necessary to be at TDC or anything special that needs to be done to remove the bolt for the impulse rotor?
2. What torque should I reinstall the bolt at?
3. There is a bolt hole on the rear timing belt cover that is in the way when trying to replace the sensor. (Circled in RED) Do I need to remove the rear cover to replace the sensor? Is there a trick to getting around this rear cover bolt? I suspect I forced my way around when I replaced the CPS last time and this is the result.
Seems like it should be as simple as removing the current impulse rotor with that 1 bolt, cleaning things up, replacing and putting in a new CPS. Is there anything I am missing?
