question to those who have done it-
how hard is it to remove and replace the plastic lenses from headlight housings? In looking at the info forum- scuba's joey-modded HID-looks, i basically found that you heat up the edges to get the glue soft, then pry with a screwdriver, is that all? And when replacing the lenses, you just heat them up again to get the glue sticky?
I just got a sweet deal on used HID's (thanks again, rob!), the lights work perfectly, though the lenses look like they could use a little polishing on the inside to make them bright and clear again... just wanted to see how much would be involved in attempting that project....
TIA!
TIA!
