1 - 8 of 8 Posts
Can't seem to find Relay 173 on my new (2004.5) Variant- is this
still the correct relay to pull for DRL's? Or has it changed. :mad:
Besides the fact that my hand is too fat to really fit into the
electrical area :oops: , I am also concerned about bumping too
much stuff around- don't wanna f#^ck something else up!
Where is it????
Also- how can I disable the friggin' door chime while I'm
at it?
Thanks everyone. A noob who needs your help!
I believe I was able to get to mine by dropping the lower dash panel below the steering wheel to gain access to the relays.
you have to drop the lower dash panel and its hidden behind the 384 relay, i did it sunday :poke:
To remove the switch, with it in the off position, push it IN and twist to the right as if turning them on. It will release and pull out.
Knowing that I can just do that with the pins I might do it instead.
1 - 8 of 8 Posts
