I've got a pair of 2001 Passat Wagons - a nice 5 speed car with a trashed engine, and a wrecked automatic car with a good engine. I already have the good engine pulled, and am getting a list together of things to fix/replace before installing it in the new car. So far I've got...
Full Timing Belt Kit
Accessory belt and tensioner
Thermostat
Spark Plugs
Crankcase cover and valve cover gasket kits
Replace all vacuum lines
Swap the slightly used alternator from the old engine
Undecided on which AC compressor to use, as well as whether the clutch should be replaced.
Anything else I need to add here?
Thermostat
Spark Plugs
