1 - 20 of 39 Posts
Hey all. rebuilding my AUG code 1.8T. I completely stripped the engine down to the block.
degreased everything, and coated the parts with Rustolum X2 Paint. the stuff works really REALLY good on engine parts.
Parts so far.
DnJ Forged 81mm Pistons
Maxspeeding Forged Rods with ARP 2000 bolts
ITM Bearings, Gaskets and Seals. with a Victor Rienz HG set.
New Tensioner Pad unit and Chain.
Gates Timing belt.
ITM Waterpump
I am also doing a Fully external oil cooler. I completely removed the water/oil cooler. cut the tube down and fitted a 10AN port adapter that is in my pictures. After I create all lines needed I will add pictures of that!
please enjoy. this have been heaps of fun for me.
The pictures really make it a lot brighter then it is, but will mellow out a bit once installed in our car and the other parts are around. Thanks man, have been a lot of fun. going for 300hp right now since we are still FWD only. I am wanting to do the AWD 6speed system in her next.
Looks nice. Did you paint the contact points between the brackets? If so, you need to clean it off as some are needed to conduct electricity.
Reactions: cchief22
Hey PZ, Thank you. I tried to leave as many of the mount spots bare for grounding and all.
Discussion Starter #8
Basically done for now, Until my Header, Cat, and Hot housing come back from jet hot coatings. the Silver Fuel rail and coating the water pipe Silver really toned down the Orange as I thought it would.
Now would be a good time to look at doing an electric fan (EFK) in place of the belt driven one. Free up a pony or two.
Honestly, I cannot remember. Whatever fit in the shroud and was shallow enough not to hit the nub from the fan pulley that was removed.
Discussion Starter #14
Ah not worries VAGguy, I will do some checking and measurements. seams like a 16 inch would do for the space.
Discussion Starter #17
Thank you mr.loops ^_^ Should be close to running tomorrow. waiting on my 4 to 1 header, CAT and Hot housing to come back from Jet Hot Coatings.
Discussion Starter #18
Pleased with the progress on Glauben today. Oil cooler is set up * reused from my 2.7t. little large, but we live in the Mojave Desert and we can reach 115 degrees during the summer.. Drivers side is basically done. Next will be the Passenger side with the header, turbo and Cat once back from jet Hot. FMIC and Cooler fit perfect under the bumper cover. retain my Family sleeper look lol
Discussion Starter #20
Now that you have invested all of that into the engine, are you going to give the car an new coat of paint or wrap?
That is on the list to be done later. for the peeling clear I have a plan to fix that at least until can get a proper paint job done.
1 - 20 of 39 Posts
