Before you do the job, see if you can determine if the yellow bump stops at the top are still intact. If not they are cheap and worth replacing when you do the shocks. At about 3:40 in the B5 version video, you will see the tech use two specialty tools to remove the shock's shaft from the mount. Two notes about this. Not all aftermarket shocks are the same. Bilstein's shocks are slightly taller 1/4", and the tool used to release the shaft of an OE shock will not fit on them. So what to do? Use vice grips at the top of the shaft above the travel of the shock itself to hold firm while removing and installing the nut.
On the B5 all the bolts are one time use. Get new ones they are cheap. The guys who do the videos I linked below never tell you if you need to replace them. They also never give you the torque specs.
B5
2-Nut
- Always replace each time after removing
3-Bolt
- 50 Nm (37 ft lb) and turn 90° further
- M10 x 90
- Only tighten when vehicle is standing on wheels.
Sorry, I can't find a reference for the 5.5 Maybe
@VAGguy has them.
Its an easy job even on my B7 where I have to lower the rear wishbone and pull the spring to get to the lower shock bolt. I spend more time jacking the car up and down than I do replacing the shocks.
B5
B5.5
