so my rear left window wasnt working and when I took out the cover, I saw that the white pulley and the cable that drives the window up and down was all broken. so I ordered a repair kit from ebay for $20 from a seller in Turkey. Item arrived pretty fast and I worked on in last weekend.
now when I close the window, it goes all the way up and then comes down again. if I close again, then it goes all the way up and stays closed.
I have read several different post and tried these but no luck.
1) roll window down and hold the switch down for 5 seconds. roll it up and hold for another 5 seconds
2) From outside, put the key in the door, and hold on lock position for until all windows are up. hold on unlock position untill all windows are down.
I havent tries disconneting the battery cable and touching them to each other.
any other ideas?
Running the window all the way up, then moving the window switch to "UP" again for a second or so seems to be the way to adapt it.
