1 - 2 of 2 Posts
Hello there, I hope someone can help me. My rear fog light and reverse light is not working. I have replaced the wire loom in the boot but still no joy. Is it possible to relay a new wire from the light switch as I suspect the wire harness has been damaged somewhere between the front and back and if so, what pin would it be on the back of the light switch? Any help will be greatly appreciated.
Search for rear fog light installation in the main vwvortex forum. The pins are discussed in detail. How did they stop working, there should be error codes on the dash... did you change the bulbs recently?
1 - 2 of 2 Posts
