Hello everyone!
Car is a 2008 VW Passat sedan. I had noticed a week or so ago that my rear driver's side door was not locking, and the window was not responding. Here's what I've attempted thus far:
This leads me to believe there's a specific part in this door that has failed. I can also lock the car, but still open this door, even with the alarm set. It's as if the door doesn't exist to the car. I was able to manually lock the door for now using the emergency key and the slot in the door jam. Is there a particular part that might cause this specific issue? Thanks in advance!
- Brandon
- Took door panel off and visually inspected, didn't find anything
- Checked the 30A fuse for the rear door function control modules (#23). No issue.
- Took off rubber wire cover between door and car, inspected wires and connectors. Everything seems fine. (photos attached)
- Brandon
