1 - 3 of 3 Posts
Not sure, but I think the door will fit.
But the door controller (window motor) won't work.
Seems like the part number of the door are the same for pre-lift and after-lift.
However I found that this strip is different and the hole in the door fot this strip also is slightly another position. Check picture below. Left is pre , right is after lift.
and here you can see pre-lift strip on after-lift doors.
1 - 3 of 3 Posts
