1 - 10 of 10 Posts
Tried using search but couldn't find a thread. My rear cupholder on my 99 V6 has broken. The slide out part comes all the way out. Has anyone r and r'd this cupholder. How to??
Thanks
They're a breakaway design. At one point in my life, I had a PDF file on how to fix the rear cupholder, but I can't find it... :mad:
Anyways, the trick is to get the sliding piece under the rear ashtray all the way out. You remove the rear ashtray, which will reveal the guts of the cupholder's sliding assembly. You gotta reach in and fiddle with the mechanisms until you can get the whole assembly to slide towards the back (i.e., the opening), and then you simply slide the cupholder back on from the driver's side to the passenger's side. Ta-da, you're done.
Andy
Not to sway from this topic, but in my 2003, the cupholders are in the rear armrest. Has anyone had a problem closing the plastic cover on the back armrest?
Mine is stuck somehow beween the 2 seats and i cant seem to close the thing :mad:
same problem. Its been broke since i bought the car used last year. Also the little panel on the end of it doesn't stay on either but i'll probably just super glue that.
I know im new but when i got my car mine was broken so here is what i did
Get a screwdriver or something with a point, the ash tray cover come off on one side with a little pressure, if you can move the cupholder back and forth you can begin to see how it works and how it is held on. i just took the screw driver and messed with it until it came off (the are 2 clips i the back). the front of the cupholder actually snapped off on mine, i thought i broke ti but it actually comes off
It took me about 20-30 minutes to do this and was very simple. Pics tomorrow if i have time :thumbup: Sorry so short and simple, its very late and i going to bed
good luck and hope this helps!
Ethan
1 - 10 of 10 Posts
