1 - 10 of 10 Posts
I had my rear pads and rotors replaced at 30,000 miles, stock pads and rotors, by the dealership. I am now at about 44,000 miles, and the dealership mechanic said that we have only 10% of the brake pad remaining and that we should replace the pads and rotors. The 30,000 service was in June 05. This seems quite a bit soon for me, as the first set of rear pads lasted 30,000 miles. Any advice would be appreciated.
take a look yourself.
that is waaayyyyy to fast to wear out.
unless they never changed them the first time.
is this is the same dealer who ripped off your wife /you with that 465.00$ belly pan and hardware repair job , in your other post, i would find anothr dealer or indi import mech fast!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Rear brakes should last longer than that. My 98 Passat had the rear pads done at 90,000 for the first time back when my sister-in-law still owned the car. And all I did was piss cut the rotors to get rid of the glazing.
Rear pads are a DIY... Save big bucks that way. Many places "rent" the needed caliper tool for free with a 100% refundable deposit.
Once the wheel is off, inspect the rotor. If you have a vernier caliper, as long as you are above the spec 9.4mm, just go with fresh pads. The calipers do not even have to come off; it is quite easy....
Hope this helps,
Cheers,
Malcolm
And in addition to the above suggestions, drive 5 more miles and go to Douglass VW in Summit. I work for the NJ division of consumer affairs and our office of consumer protection always has cases against the whole DCH orginization. Douglass though has literally ZERO. When I need a dealer for service it is where I go. If you want a great indy, check out Egentons in plainfield.
1 - 10 of 10 Posts
