Hi all,
I am trying to replace the rear pads on a 2000 Passat GLX and can't seem to get the wheel cylinder to retract. I tried to compress it with a C-clamp as I've done with other cars but it feels locked in place. The rotors are only slightly worn and polished so I think the caliper has been working OK. The pads are fully worn, so the piston is mostly extended.
Does the antilock have a one way valve that prevents backflow? and therefore prevents the piston from retracting? could it be extended to the max and therefore out of the caliper? If so anyone have instructins or a manual that gives the reinstall instructions?
thanks in advance
BObZ
_________________
BobZ
2001 B5 Black GLX
1997 BMW 540i 6 Speed
1972 Triumph Bonneville 650cc
thanks in advance
BObZ
_________________
BobZ
2001 B5 Black GLX
