1 - 7 of 7 Posts
[2001.5 Passat 4cyl. ] Stopped for gas cut off car but left radio on. Upon entering car after fueling the radio was off. When I tryed to turn on the Radio (Screen Reads '' Safe ") ..no buttons are working. What did i do? Help!:banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
have to get the "safe"code for the radio,check you manual the code sould be in there,if not just buy aftermarket,lot less trouble and probably cheaper
If you bought the car new the dealer most likely has the code. Like the other post said it is on a card that is in the owner's manual, if you haven't removed it and put it somewhere else. If the car has been serviced at a dealership and for whatever reason they needed to disconnect the battery they'll have the code. Good luck!:thumbup:
1 - 7 of 7 Posts
