Did a full scan tonight with the VCDS and I found this:
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 M HW: 1K0 035 180 M
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7I3162273
Coding: 0010400
Shop #: WSC 00000 000 00000
VCID: 2A50EFDDFC8D
2 Faults Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
01042 - Control Module; Not Coded
000 - -
What does this mean? My radio works fine.:hmmm:
Moderate Moderator
Check the radio coding to see if it's set up properly. You're currently codded 0010400. The coding you should have depends on the options installed in your car.
I wonder if your software coding is set for some hardware feature you don't have. The #2 antenna open circuit may be a product of a coding error. ie, it's expecting to see an antenna your car isn't equipped with.
When I bring up the coding window for my B5 radio, vag-com pops up a helper window that explains the coding options.
It's worth a look. Hope it's as simple as this.
It may be coded for a cd changer and it may not be there or it is and not coded for it. I can't remember the the codes for that, it's been like 10 yrs since I did a PDI. THey came off the truck not coded for changers and most had them and needed to be coded correctly.
