I have. What you can do is use a heat gun and heat up the plastic duct back there. Once its soft and pliable use a piece of wood to push it back as far as you need to. DO NOT TOUCH THE PLASTIC WITH YOUR BARE HANDS!!! You will need to hold the wood in place for a period of time so maybe prepare a way to brace it. The plastic will then be shaped how you like.
Just for the heck of it but check to see that your problem isn't with the wiring back there hitting the DD frame piece. I know its a tight space back there but I've gotten my Kenwood and my indash screen to fit back there. If you have a pocket below the radio first put the radio in then pull the wires down and put the pocket in. It may be tough but trust me it works.
