1 - 15 of 15 Posts
How about the Audi TT pedals for the 99 B5? And if it is an Auto (Tip) then the new TT has a tip version this year. Not sure if these fit but worth a look. Maybe someone else knows.
I have the Anni pedals on my Bora, which i have removed in order to sell the car.
I'm hoping to buy a B5.5 once it is sold, and having looked at a few, the R32/TT/Anni pedal covers will not fit the B5.5 Passat. I am not sure about the B5, as I have not looked at the pedals to see their size.
Are the B5 & B5.5 pedals the same size ? If so, has anyone got a picture of the Phaeton pedal covers ? I'd be grateful to see them.
Anyone have a pic of the Phaeton pedals (you say they fit the B5)?
the R32 has an auto version? i would like to see the jackass who would buy a auto R32|!
Rae
The auto version fo the R32 if called the DSG. This is the one with the paddles and the tranny is actually a manual without a clutch pedal or you could put it in drive and the TCU would do the gear selection.
This is also a option on the Audi TT 3.2
You do know that these cars are built on the same basic floor pan layout Right :???:
Rae
The auto version of the R32 is called the DSG. This is the one with the paddles on the steering wheel and the tranny is actually a manual without a clutch pedal or you could put it in drive and the TCU would do the gear selection for you. You should do a search and check out some technical information on that drive train.
Rae
Didnt know that! but still think that an R32 with a stick would be more fun than with the paddles! Thx for the info though, a man is always learning!
I am interested Steve...Are the auto pedals an easy fit for my B5? And does it include the dead pedal?
Dead pedal is included, and the install is basically the same as those with a clutch, brake pedal is a direct swap, gas and dead pedals use the same installation tricks as the clutch set-up. You won;t find a nicer, better fitting factory solution.
1 - 15 of 15 Posts
