I am currently upgrading my AWM 1.8T with a GT28R Garrett. For the moment I will only be able to hook it up to the OE manifold and other Oe parts using adapters. Once I have the $$$ to do the custom stainless steel manifold, FMIC, upgrade the exhaust pipping to 3" and 3" DP. Hopefully in the next month or two. Then I will be running nice.
I am currently using a 2003 1.8T AWM 170Hp with the Revo 4 Bar software, Forge DV with yellow spring, K&N drop in, H-Valve, Remus exhaust with custom 2.5" DP, High Flow cat, and 2.5" pipping for the Cat Str8 back to the muffler.
My question is will the Forge DV 007 hold up better then a Blow-Off valve? Should I upgrade the DV for a BV???? would there be any interest in my DV if I should upgrade???
Chris
Chris
