1 - 17 of 17 Posts
Does piston go clockwise or counterclockwise when retracting the piston. Also I bought a KD disc brake tool for the rear piston, it looks like a building block with different ears on it and it fits onto a 1/2 drive. Will it work!!!!!
Michael
Almost positive it will turn clockwise, but it's been awhile since I did a rear set.
Not sure about the tool - I bought a MetalNerds one. Worked really good on the fronts and rears.
Just be careful to not tear the rubber boot around the piston.
Clockwise , now I've a question, lol sorry for hijacking this thread... When you are compressing the piston front/rear, do you need to uncap the brake fluid reservoir?
Thanks I just remember putting brakes on a coworkers GTI and turning the piston the wrong way and it came out. What a pain getting it back in.
Michael
I usually do and place a rag around or under it to catch whatever minute amount of fluid that may spill out.
Michael
You'll have to push while you turn. The kind with the threaded plunger is MUCH easier to use.
Both pistons turn clockwise to retract; they are NOT mirror images, as on typical self-adjusting drum brakes. I strongly recommend the Harbor Freight brake tool retractor; forum members living in my general geographic area are invited to borrow mine.
Discussion Starter · #9 ·
I repeat DO NOT use the cube type retractor that mounts to a 1/2 drive. IT BLOWS. My wife had to rent me the tool from Advance auto and it worked like a dream. I had to finish up after working a viewing and man was it dark in my garage..next weekend project Add light to the garage. Thanks for the help
Michael
Turkey baster works good for siphoning off fluid - do NOT ever use it again for food preparation though (I bought a new one for 3 bucks, and threw it away after I was finished).
I have speed-bleeders installed so I just cracked them open and let the fluid drain out during retraction. Valid concern or not, I didn't want to risk any damage to my braking system from the back-pressure.
You can get the tool for *free* from Autozone for a 100% refundable deposit ($35 in my case.) It worked great.
can someone post a part number or picture of either the harbor freight tool or the autozone tool? Just want to make sure that I get the right one... thanks.
1 - 17 of 17 Posts
