Looking to go with 18 inch wheels...I have found a set of icon wheels that I like and they are 18 x7.5 with a 45mm offset...I dont want them to stick out of the fenders...Will these work or should i go with a lower offset
The lower the offset, the farther out they stick.soundfxinc said:45mm offset...Will these work or should i go with a lower offset
Hey I think its the other way around.JimmyDee said:The lower the offset, the farther out they stick.soundfxinc said:45mm offset...Will these work or should i go with a lower offset
35mm offset is premium for Passats. You can run pretty much anything between 30mm and 45mm.
I have a set of BBS RA's with a 30mm offset, and they come almost to the edge of the fender (they are also 8.5" wide).
Jimmy![]()
therefore the wheel gonna be more into the wheel well. if you have negative offset, the wheel gonna stick out of the wheel wellsTHe bigger the number ie: 45mm ET the more the HUB of the wheel sticks out
Yeah you're right. I am confusing myself.b5_99 said:LoL, eurotall, you're confusing yourself. You got it right the first time:
therefore the wheel gonna be more into the wheel well. if you have negative offset, the wheel gonna stick out of the wheel wellsTHe bigger the number ie: 45mm ET the more the HUB of the wheel sticks outoke: and after all, we're all correct
